Electrical issue 84 trans am 305 lg4
Old Apr 1, 2023 | 10:39 PM
Boot410's Avatar
I have a 84 trans am that runs good but for some reason nothing on the dash works at all and radio doesn’t come on and I can’t get any readings when I test the fuses in the box on the inside the test light doesn’t light up on any of them but my tailights and horn and headlights work, i believe I have tested the right wire that goes to the fuse box but not exactly sure.
But my main thing I have found out of place was a wire I seen while I was looking for fusible links, I got a picture of it I will include but it is connected to the back of alternator and looks like it’s supposed to go to battery when I put the test light on it has power and the carburetor starts clicking like it would you turn the switch to on. Was wondering if any has answers on what the wire is and what it connects too. I am holding the wire in the pictures
Old Apr 1, 2023 | 11:22 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Electrical issue 84 trans am 305 lg4
I can't see where that wire is coming from, but the first thing I would check is the fusible links that connect to the positive terminal on the starter...
Old Apr 2, 2023 | 12:05 AM
vorteciroc's Avatar
Top Answer: 1
That Images appears to be of a Cut/ Broken Fusible-Link that powers one of the Multiple 12v+ Wires to the PCM.
Old Apr 2, 2023 | 08:36 AM
Boot410's Avatar
so do you think it hooks in with the positive terminal of the battery it looks like it goes straight to that I will get more pics of the wire later. Thanks for all the help.
Old Apr 2, 2023 | 10:28 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Roger Davis
Dec 18, 2011 12:56 AM
MY84CAMARO06
Nov 13, 2006 09:56 PM
cdoyle
Sep 23, 2006 05:15 PM
Larry Dunlap
Car Audio
Aug 9, 2004 04:59 PM
Tongi
Apr 11, 2002 10:16 AM
