altenator comming loose
Car: 1984 CAMARO
Engine: 305 H.O Z28
Transmission: 5 SPD
Axle/Gears: DONT KNOW MUCH ABOUT CAMAROS
charging problems
my car would not hold charge..i changed batteries.still not holding charge..tested altenator ..passed...so i checked the power wire that goes into the altenator from the ignition i think.no volts to the wire..so i was told to run a power wire to it from the battery possitive..it fixed the problem..is it going to hurt my altenator?or battery?(poer wire was called pin 2 i think)
i got an 84 camaro w/ 305 h.o
When you turn the key to On, with the engine NOT running, does the "Choke" light come on?
If not, change that light bulb, and see if that fixes it.
PATRIOTIC1911
Northern Great Plains and Rocky Mountain
Oct 7, 2022 10:38 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
