Vats system vs passkey???
Old May 8, 2023 | 11:04 AM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
I was looking at getting a new steering column . I currently have a vats system the new column has passkey which I belive is older version. Is this compatible?
Old May 8, 2023 | 11:39 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Vats system vs passkey???
VATS is Passkey, they are two different names for the same thing.
https://www.transpondery.com/vehicle...scription.html
Old May 8, 2023 | 03:19 PM
Engine: 5.7 l98
thank you ,next question is if I get a different column with a different resistance how do I resolve that.
Old May 8, 2023 | 03:58 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You have to have the matching passkey module for the resistance of the key or swap out key cylinder with old cylinder
Old May 8, 2023 | 04:04 PM
Engine: 5.7 l98
okay so I just bought a new column with a new passkey module and key. What do I have to do to make that work with my current system thanks I couldn't find these exact answers anywhere else
Old May 8, 2023 | 04:12 PM
Engine: Lb9
Transmission: M20
Use the matching module and tear apart half the dash or use your old key cylinder and old key.
Old May 8, 2023 | 04:14 PM
Engine: 5.7 l98
so if I replace the old module with the new one and just plug it in everything will work as it should.. I probably will wind up doing that considering I need to do heat core anyway. Thank you
Old May 8, 2023 | 07:52 PM
vorteciroc's Avatar
Top Answer: 1
Technically for GM, "VATS" stands for: "Vehicle Anti-Theft System".
GM has Two Sub-Systems of VATS:
-1: Pass-Key (Found in our Cars), Pass-Key II, and Pass-Key III (Until recently Modern GM Vehicles would have either "PK3" or "+" on the Key for this System.
-2: Pass-Lock (another System with multiple revisions, and the Key is NOT part of the System, just the Lock-Cylinder is).
mackjar66
Jan 31, 2015 07:53 PM
MetabolicHigh
Mar 18, 2013 11:19 PM
clay_mickey
Jan 27, 2012 07:46 PM
