Heater Delete
Old Jul 9, 2023 | 06:21 AM
Fluffaluffigas's Avatar
Car: 1985 Chevy Camaro Sport Cruiser
Engine: 350 SBC
Heater Delete
Hi guys! Is it hard to remove this heater box? The hoses are already not hooked up, it works from the inside just fine but I assume any air I’d be getting is just hot air from inside the engine bay.
I’d love to remove the entire unit, put a nice steel or aluminum plate on the firewall and remount the ignition coil so it’s vertical again. Any advice would be appreciated, I don’t know much about the heat/AC on these ones!
Old Jul 9, 2023 | 02:53 PM
shaynecastongua's Avatar
Car: 1985 Trans Am
Engine: Chevy 355
Transmission: T5 NWC
Re: Heater Delete
It's not too bad to remove. The only fasteners for the heater box itself are around the edge of the box. I can't quite remember how many there were but definitely start at the bottom and save the accessible top ones for last. If you remove the bottoms first the heater box has a tendency to sag and obstruct your hands.
There's a seal between the firewall and box, you'll probably have some stuck to the firewall that needs to get cleaned/peeled off. If you don't ever plan on re-installing you can remove the wiring harness from the climate controls inside the car to clean things up more too.
dcd2236
Aug 29, 2014 12:22 PM
John in RI
Sep 25, 2008 10:27 AM
nick05
Feb 18, 2006 12:02 AM
cobrakiller1989
Nov 4, 2004 01:56 AM
FatOne
Jul 8, 2002 02:49 PM
