Having trouble adjusting IAC
Car: 1986 Camaro Z28 Iroc-z
Hey guys I have an 86 camaro iroc TPI with a swapped 350 in it, automatic transmission, I tried following the instructions on setting the idle, but once I put the pins in the ALDL and wait 30 seconds and disconnect the IAC connector the car will not start. What am I doing wrong ? Is there a different procedure I should follow ?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Having trouble adjusting IAC
After you unplug the iac connector, remove aldl jumper you might need to adjust idle up or prop open the throttle stop to start if it’s closed to much.
