Where to put ICM
Old Sep 18, 2023 | 12:30 PM
dylan0503's Avatar
Car: 1987 Firebird Formula
Engine: 305 Carbureted
Where to put ICM
So I need to move the ignition module because on my old engine it was in the distributor but now it’s not. Can I just put it in the firewall or something like that? If so, how do I get power to it?
Old Sep 18, 2023 | 01:13 PM
Re: Where to put ICM
I'm guessing this is related to your other posts about this (changeover from small-cap w coil mounted on intake to large-cap w coil-in-cap) that don't make sense either.
The ICM is INSIDE THE DISTRIBUTOR. The harness that comes out from INSIDE THE DISTRIBUTOR carries power to it from the terminal on the OUTSIDE of the dist.
https://www.jegs.com/i/JEGS/555/40005/10002/-1 for example
Observe the harness with what looks like red, black, & yellow wires. The end of it you can't see plugs into the ICM, INSIDE THE DISTRIBUTOR.
Old Sep 18, 2023 | 06:49 PM
vorteciroc's Avatar
Top Answer: 1
From the lack of Details...
I do NOT exactly know what you are doing.
However if you have a fully Electronic Advance Distributor (Like the Vortec 350 Engines)...
You would use something like the Image below for the ICM and Coil:
Midnight85
Feb 14, 2014 06:48 AM
burn0ut305
Jul 7, 2013 09:43 PM
no4N_junk
Apr 25, 2013 03:01 AM
IROCaholic
Sep 6, 2004 02:50 PM
Luther6704
May 26, 2002 08:03 PM
