Plug under driver's side
Old Jan 17, 2024 | 10:40 PM
dcd2236's Avatar
Car: 1987 trans am, 1988 Formula
Engine: 305 LG4, 305 LB9 TPI
Transmission: 700R4 in both
Trying to remember what all connections I have. Can't seem to remember what this heavier gauge yellow purple wire and plug goes to.
Old Jan 18, 2024 | 01:02 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Plug under driver's side
Large purple wire is typically part of the starter solenoid circuit?
Old Jan 18, 2024 | 08:33 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I "think" that goes to the starter enable relay.
Old Jan 18, 2024 | 10:12 PM
dcd2236's Avatar
Be nice to see that plugged into what it's supposed to be in a photo of an untouched original car as a reference
Old Jan 19, 2024 | 12:18 AM
Drgnbld's Avatar
Car: 89 GTA
Transmission: auto
Axle/Gears: 3.23 BW 9 bolt
Neutral safety switch for a manual car
Old Jan 19, 2024 | 07:13 AM
dcd2236's Avatar
This car is a factory tpi automatic car. No manual transmission
Old Jan 19, 2024 | 09:09 AM
ughmas's Avatar
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
Don't have a reference photo for you but here's the diagram, others are correct this is for the starter circuit
Old Jan 19, 2024 | 12:28 PM
The harness has all the wiring for both auto and manual, to keep production costs and chances for error down.
Old Jan 19, 2024 | 06:41 PM
vorteciroc's Avatar
Top Answer: 1
Some Cars were done that way and some were not....
It varied from Model-Year to Model-Year.
Damn Bureaucrats can't decide anything, and usually screw everything up!!!
Old Jan 19, 2024 | 08:46 PM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
My auto car had that wire. It was very convenient when I swapped it to a stick!
Old Jan 19, 2024 | 09:38 PM
dcd2236's Avatar
So from the sound of it this wire is just "there" in an auto car and more for manual transmission cars
Old Jan 20, 2024 | 10:17 AM
Look at the schematic. It tells you all you need to know. In a manual car, that one is for the clutch safety switch, which does THE EXACT SAME THING as the neutral safety switch in an auto car. In a manual car, the auto NSS connector can be found dangling under the console, just like that one is now doing in your auto car.
Clements408
Oct 20, 2022 05:48 PM
Saculia
May 3, 2008 10:39 AM
IROCFAST
Jul 29, 2007 05:19 PM
84camaroZ
Oct 29, 2005 02:15 PM
SgtSkip
Jan 25, 2002 10:20 AM
