Air intake connection
Old Jan 30, 2024 | 09:29 AM
Reim's Avatar
Car: 1987 Camaro IROC
Transmission: 700R
Axle/Gears: G92 3.23
Hi everyone - I am back on the IROC and have a question I cannot find an answer to. On my stock air intake there is a sensor that my car does not have a harness to plug into? I have included a picture. Appreciate the help. Thanks.
Old Jan 30, 2024 | 09:31 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Air intake connection
That’s a v6 air filter lid. You mat is under the intake plenum.
Old Jan 30, 2024 | 11:17 AM
Reim's Avatar
Transmission: 700R
Really? Mmm so it was replaced at some point?
Old Jan 30, 2024 | 11:21 AM
Engine: Lb9
Transmission: M20
apparently
Old Jan 30, 2024 | 11:36 AM
Reim's Avatar
Transmission: 700R
You are right! Problem solved. The car was never in an accident and PO had the car for over 21 years. Mmm, maybe they had another intake on it and he bought this one when he sold it. The car was never in a wreck I checked it out good.
Thank you sir.
Old Jan 30, 2024 | 04:10 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I'd use that sensor in the air duct. ( just my !)
The TPI sensor is mounted to the Plenum where the incoming air is warmer due to it's position mounted on the motor. ( screwed into a thick piece of aluminum) The readings taken at the very front of the air ducts ( sensor screwed into plastic ) *should* be a little colder; AKA more accurate.
You'd just need to cut the plug off the harness and add some wire and reconnect the plug so it will reach all the way to the new sensor location.
Old Jan 30, 2024 | 08:25 PM
Reim's Avatar
Transmission: 700R
Ok really. I will do that. I appreciate the information sir. That’s awesome!
MikeT290
Feb 12, 2023 08:38 PM
LGS_18
Jan 8, 2017 10:46 PM
jkwild0630
May 7, 2006 10:59 PM
82CrossfireInj
Fabrication
Jun 27, 2004 11:14 PM
