Sflp altinator wiring
Old Feb 3, 2024 | 03:48 PM
FadelessRyuu's Avatar
Hello i drive an 87 camaro named medusa, she has a 350 sbc has edelbrock intake and edelbrock 600cfm carb electric choke. When i bought the car it had a powermaster altinator that did not seem to charge battery. I bought new altinator and battery both work ive tested at store and on another vehicle however once i put it in my camaro it doesnt work. Grounds are all good however the plug for the alt is a 3 wire sflp plug and the middle wire is severed, the car has ecu deleted but i have a feeling that one wire could be my problem. I wish to rewire the alt plug where should i re run the wires too? Big red wire from plug is going to starter at the moment farthest brown wire seem to be wired to the ignition in dash with voltage guage in that loop, no clue where middle brown wire should go. I honestly want to cut the plug off and re wire the altinator plug properly im just having a hard time finding the proper wiring diagram and information as to where the wires should be plugged in and which one is the alt exciter wire? I attached photo of plug coming off the altinator. Dont mind the surface rust as everything is being replaced over time and treated
Old Feb 3, 2024 | 04:40 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Sflp altinator wiring
I’m pretty sure it’s a variation of the cs130
might search google or it could be here
https://www.thirdgen.org/forums/elec...-cs-130-a.html
https://austinthirdgen.org/thirdgen-...te-background/
Old Feb 3, 2024 | 05:04 PM
I know the "s" is sensory wire. I just dont know what the f.l.p. is there is no wire for the p so the wire lead out from the s.l.f. portion of the plug
Old Jul 8, 2024 | 11:40 PM
PapaRoach3's Avatar
Welcome to Gboard clipboard, any text you copy will be saved here.
Iroc-Dennis
Feb 12, 2024 03:53 PM
KYLE87
Sep 2, 2008 12:27 AM
85camaro350
Aug 11, 2004 02:35 AM
MartinC
Jan 30, 2003 06:23 AM
Spifz
Oct 25, 2002 02:28 PM
