Horn testing
Old May 31, 2024 | 07:18 PM
2names's Avatar
Car: 88' Iroc convertible
Transmission: 5spd
Horn testing
Hello all, I tried to search this on the forum but if it is on there it's lost in the sea of info, but I am looking for the process of testing my horns with a volt meter.
I've traced my blowing fuse problem in that direction and would like to confirm my suspicions.
Thanks!
Old Jun 1, 2024 | 09:34 AM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Re: Horn testing
Easiest way to determine if it's the horn themselves is to disconnect the connector from each horn individually, and with a good fuse in place, press the horn button and see if the fuse blows. If the fuse blows with the horns disconnected, the horns should be fine and your short is further up the line.
thatoneguy5x
Sep 14, 2013 08:04 PM
richterbelmont2
Aug 3, 2012 10:01 AM
91Formula305TPI
Apr 17, 2010 02:48 PM
yOp 84 Recaro
Apr 19, 2002 06:56 AM
