Horn blows acc fuse
Old Apr 10, 2010 | 10:47 PM
91Formula305TPI's Avatar
Horn blows acc fuse
Been a big fan of this site due to the many questions answered here. My problem is everytime i try to use my horn it blows the acc fuse. This happened after my horn button on my grant steering wheel decided to pop off while i was at a restraunt and the only guess i had was that it was too much for it and somehow overloaded the system. I drove it home and replaced the acc fuse. I notice that when i hit the horn it dims the dome light and i can hear the relay clicking. Thought that the relay was dead so i replaced it too. Hooked a test light up to the horn wire and it lights up when i hit the horn. I am now lost as too why this is happening. Any ideas? Thanks for the help Mike
Old Apr 11, 2010 | 05:55 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: Horn blows acc fuse
Hello 91Formula305TPI!!
Sounds like you have a power wire touching something!!!
The acc fuse runs a few things, does using the cigarette lighter blow the acc fuse also???
Recheck the horn wire for chaffing!!
P.S. Just wondering if you get a shock when you try the horn while touching the metal part of the steering wheel??? You can use the test light to test this out!!!
Old Apr 11, 2010 | 07:58 PM
bcmag's Avatar
sounds like the horn itself maybe be shorted.seen this often. try a substite horn.also cant remember if these are single or two horn systems...if it has two check both.
Old Apr 11, 2010 | 08:24 PM
Hello bcmag!!
I should have thought about that, I assumed that the horn did work, but kept blowing the fuse, but re-reading the OP's post, I have to admit, you may be right!!!
Old Apr 11, 2010 | 08:32 PM
Connect a test light at the end of the wire connector where it connects to the horn(s), and replace your fuse, then press on the horn, and see if it blows the fuse!!
If it blows the fuse, you should have a problem in the power wire in the horn circuit, if it doesn't blow the fuse, but the light lights up, then the horn(s) is/are faulty!!
Old Apr 13, 2010 | 11:39 AM
Thanks for all the info. I think that the horns did bite the dust. I am going to go buy some new horns and repost if it fixes the problem.
Old Apr 16, 2010 | 10:45 PM
Well turns out it was the horns. Installed new ones and all works like it should.
Old Apr 17, 2010 | 09:17 AM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Engine: L98 5.7 liter
Transmission: TH700r4
Axle/Gears: limited slip 3.23
just a quick question 87IROC-Dan61, if the cigarette lighter does fault the acc fuse, what does that mean? I had this happen in my car until I pulled the cigarette lighter out all together! Thanks for any and all info.
Old Apr 17, 2010 | 02:48 PM
Hello MI ROC-Z!!
It could mean a few things, the lighter it's self could be causing a short, or you could have something that broke off of the lighter jammed in there, or even the orange wire could be touching something metal behind the dash, like one member had!!
My kid tried one of those "fancy flashing light" things in his cigarette lighter socket, and it kept blowing the fuse, he took my advice and threw the crappy thing away, changed the fuse, and never had a problem since!!
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
usafirebird
Sep 29, 2015 11:58 PM
