Pink and white distributor ignition coil jumper
There is a pink and white wire about 8 inches long that goes between the distributor and the factory ignition coil. Does anybody know where I can get one?
I'm trying to diagnose why my mega-squirted car is not starting, it doesn't have an ignition/timing signal while cranking and I'm trying to eliminate the aftermarket ignition/ignition coil but to do that I need to re-install a factory setup and that jumper wire is the only thing I can't seem to find.
Transmission: T-5, TH350, T-5
Re: Pink and white distributor ignition coil jumper
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
