Direct Power to Power Window Motor
Old Jul 27, 2024 | 01:53 PM
M3638's Avatar
Car: 1990 Iroc Convertible
Need help powering windows to go down.
1991 Z28, 5.0, auto.
engine and transmission are out along with engine wire harness. Interior completely out except for dash and dash wire harness. Wiring for power windows is there at center console area.
What is the easiest way to give power to the motors to get the windows to go down?
Thank you.
Old Jul 27, 2024 | 03:25 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: Direct Power to Power Window Motor
Could use a power probe or any other kind of 12v source and send 12v to the correct power window switch wire and then hit the window switch in the desired direction. Could also do it at the motor/after the switch if you know what wires are up and down
Old Jul 29, 2024 | 09:38 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
What TylerSteez states works.
Old Jul 29, 2024 | 08:18 PM
M3638's Avatar
I bought a probe and it worked. Thank you.
McCall
Jan 30, 2020 06:41 PM
'86 Camaro BoSs
Apr 20, 2007 04:27 PM
Firebat
Jul 6, 2006 09:57 PM
1987camarosport
Jan 16, 2005 10:14 PM
