1989 TPI ecu/harness into 1986 TPI iroc
Old Sep 7, 2024 | 06:33 PM
LSZ28Ss's Avatar
I got a good deal on a whole 89 tpi set up including harness and ecu . I’d like to install it on my 1986 soon to be L31 swapped TPI, will this work?
Old Sep 7, 2024 | 08:35 PM
LSZ28Ss's Avatar
Re: 1989 TPI ecu/harness into 1986 TPI iroc
Old Sep 7, 2024 | 09:40 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
90-92 speed density, it’s not from a 89
Old Sep 7, 2024 | 10:59 PM
LSZ28Ss's Avatar
it it possible to run this on my 86?
Old Sep 8, 2024 | 08:06 AM
Engine: Lb9
Transmission: M20
With reprogramming, yes you can install the sd harness and run $8D
Old Sep 8, 2024 | 11:08 AM
LSZ28Ss's Avatar
Is it plug and play besides the reprogramming. I found a write up and it looked like there was alot of repinning and soldering involved.
Old Sep 8, 2024 | 11:47 AM
Engine: Lb9
Transmission: M20
The street and performance harness is plug and play with ground hookup, hot at all times fused power and accessory power. You will need to tie is a Vss signal from buffer to ecm optical input.
LSZ28Ss
Jul 11, 2023 09:18 PM
Johnny Blaze
Feb 22, 2014 07:17 PM
MOCCASIN
Feb 20, 2003 10:35 PM
