Electric mirrors camaro RS 1990
Old Feb 5, 2025 | 12:18 PM
lolodenimes's Avatar
Hey!
I'm working on my project car, a camaro RS 1990 V8 and i just found out that the left AND right mirrors connetics has been ripped off.
Now i have a black plug with 4 wire on one side and 6 wires hanging on the other side.
I've looked for info on forums and schematics but only find some white plugs and only 4 wires.
Did someone knows what can i do with my 6 and how to plug them back on a 4 wire plug??
If you have any schematic do not hesitate to share!
Thx!!
Old Feb 5, 2025 | 01:23 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Re: Electric mirrors camaro RS 1990
Here are pics from my 1992 camaro FSM.
Old Feb 5, 2025 | 01:33 PM
Oh that's nice thx!
So if i'm correct, we have the 6 wires comming from the mirror correctly displayed here.
And i can assume that the 4 wires going to the control panel are the ones before the mecanically linked switch.
So it means that both white are connected together on the same port as well as greens.
But i only have one green
Two whites, one blue, one pink, one green and one tan
Old Feb 7, 2025 | 02:38 PM
Up?
No one to help on this topic?
Old Feb 7, 2025 | 03:31 PM
pirateofms's Avatar
Car: 1989 Firebird
Engine: 2.8 V6
I just pulled a full set out of a junkyard car, but don't have them on hand. If nobody else chimes in, I'll get them out tonight and send pictures of each connector and what wires are there.
Old Feb 7, 2025 | 08:12 PM
kestell123's Avatar
Car: 1991 camaro convertible
Engine: LS3
Transmission: 6l80
Axle/Gears: Ford 8.8 3.31 torsen t2r
Do you have the correct mirrors for the car?
Old Feb 7, 2025 | 09:59 PM
pirateofms's Avatar
Car: 1989 Firebird
Engine: 2.8 V6
Alright. These were taken from an 86, but it should point you in the right direction. Here's the complete setup I pulled:
Switch and plug, red wires were already cut, but they're just power.  Blue, Yellow, White, White/Black, Green, Green/Black.  This goes through the grommet in the door, plugs in under the dash near the fuse panel.
Switch and plug, red wires were already cut, but they're just power. Blue, Yellow, White, White/Black, Green, Green/Black. This goes through the grommet in the door, plugs into the harness under the dash near the fuse panel.
Dash Harness.  Black plug to switch, one white plug to each window.  Short end is driver side.  Runs across the top of the dash, tucked under the vents.
Mirror plug.  One on each side, just under the hush panel, running through the door grommet.  Green, Yellow, White, Grey
Mirror plug. One on each side, just under the hush panel, running through the door grommet. Green, Yellow, White, Grey, both sides appear to be the same.
Old Feb 9, 2025 | 06:06 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Color if it helps. From my 89 FSM.
Old Feb 21, 2025 | 11:51 AM
Thx guys, i did the wiring job correctly thx to you =)
musclecarfan87
Aug 4, 2008 08:44 AM
The_Prostitute
Oct 27, 2002 07:45 AM
The_Prostitute
Oct 27, 2002 12:36 AM
CamaroRS1990Guy
Jan 24, 2002 07:33 PM
