Instrument Panel Cluster Relay
Old Mar 2, 2025 | 01:34 PM
Nova73's Avatar
Car: 1986 Camaro Sport CP V6 MPF
Engine: V6 173cu MPF
Transmission: 700R4 Automatic
Does anyone know where this relay is located? I've lost all my gauges and I am still trying to locate the problem. Please, if you know where it's located let me know.
I need to rule this out as my problem. I just purchased one from Rockauto, and it is the same as the Blower Motor High Speed Relay-.Same configuration.
Old Mar 2, 2025 | 01:59 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Instrument Panel Cluster Relay
There isn’t a relay for ip
Old Mar 2, 2025 | 03:36 PM
Zackly. No such thing.
I'd suggest starting at the fuse. Put in a new one. Don't bother with "check"; jump straight to "replace".
Repeat after me:
When in doubt, swap it out.
Old Mar 3, 2025 | 04:04 AM
Nova73's Avatar
Thanks for that info. If there is none, which I agree with you, than why does Rockauto sell one of them. I guess only they could answer that question. I bought one and it is the one that is used for the Blower Motor High Speed Relay. Same configuration and attaches to the same bracket.
On the IP Relay list at Rockauto, Well's sells one that says " Exterior Light Control ", check it out. I don't even know what that's suppose to mean, because I can not even locate any such thing related to that. Someone or somebody, better get there facts straight at Rockauto, if there is no such relay. I am going to call their tech and tell them to get it off their website as a part, because, there is none for that engine, right?
One more thing, I just had the steering column down yesterday again and made sure the rod that connects to the ignition switch was properly seated, which it was not, so I fixed that. In the process, I noticed a black cable attached to the bottom of the switch was not properly attached and seated, so I corrected that. What is that cable for and what is the purpose of it. I can not find anything in the original repair manual that refers to it. Would that be a factor why I lost all my cluster gauges? Your help is very much appreciated.
Old Mar 3, 2025 | 01:26 PM
Because people want to buy them and they want to take their money and don't want to disappoint? Iunno.
​​​​​​​Exterior Light Control
Never seen nor heard of any such thing in these cars.
If it has about 5 or 6 wires and a sort of flat plug on the end, it's for cruise control.
​​​​​​​Would that be a factor why I lost all my cluster gauges?
No.
Old Mar 3, 2025 | 03:21 PM
Nova73's Avatar
Rockauto refunded my money. I also got my instrument Panel Cluster up and working again. I believe it was the fuse. It just didn't look right, so I replaced it and now it's back up and working again.
What is the black cable on the backside of the ignition switch for? It was out of the socket and I reinstalled it. It won't come out again.
Old Mar 3, 2025 | 04:25 PM
​​​​​​​Key buzzer?
Old Mar 3, 2025 | 07:38 PM
Nova73's Avatar
Thanks, I fixed the cable and you are right. I now have A constant buzzing sound upon opening the doors of the car. A little annoying, but I can live with it.
Thanks again, for the reply. I thought I knew this car pretty good, but everyday is a new adventure.
djmarch
Jun 7, 2015 05:58 PM
tom3
Jan 15, 2004 11:52 AM
J Kylez
Mar 29, 2003 02:24 PM
86 sports coupe
Aug 17, 2002 10:24 PM
superchevy86
Sep 27, 2001 04:48 PM
