Sort of no start 88 tpi
Old May 24, 2025 | 11:21 AM
John1975's Avatar
Engine: 5.0 and 5.7
So my 88 formula died while driving, about once or twice a day it will start for a few seconds. Excellent fuel pressure. Replaced icm. Tried a diffrent ecm. But not getting spark. Has new cap,rotor,wires,plugs. Anyone ever have this?
Old May 24, 2025 | 12:45 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Sort of no start 88 tpi
Check the output voltage of the pu coil while cranking
Old May 24, 2025 | 01:12 PM
John1975's Avatar
Engine: 5.0 and 5.7
I got .6 volt
Old May 24, 2025 | 01:19 PM
Engine: Lb9
Transmission: M20
Should be good enough to trigger the coil, is there power at the icm Koeo and cranking ? Pink wire
https://easyautodiagnostics.com/gm/4...nted-icm-tests
Old May 24, 2025 | 01:24 PM
John1975's Avatar
Engine: 5.0 and 5.7
.5 volt
Old May 24, 2025 | 01:25 PM
John1975's Avatar
Engine: 5.0 and 5.7
During cranking that is
Engine: Lb9
Transmission: M20
It takes 12v to power the coil and icm
Old May 24, 2025 | 01:27 PM
John1975's Avatar
Engine: 5.0 and 5.7
With a standard test light is has power as soon as ignition is on and slight dim with starter drawing piwer
Pink88
Oct 14, 2021 09:15 AM
TexasFormula
Sep 30, 2015 06:36 PM
whiteturbo87
Sep 11, 2011 09:41 PM
gunnman54
Nov 22, 2000 10:15 AM
