Tpi to carb
Old May 25, 2025 | 05:56 PM
John1975's Avatar
Engine: 5.0 and 5.7
Tpi to carb
What is all needed to get rid of tpi and change to carb?
Old May 25, 2025 | 07:10 PM
NoEmissions84TA's Avatar
Re: Tpi to carb
Swapping from EFI to a Carb in Camaro or Firebird - ThirdGen.Org
Old May 25, 2025 | 09:00 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Tpi to carb
You will have the same issue with a carb if you only have .5 vdc at the icm. Check power at tc100 and ign sw.
You will have the same issue with a carb if you only have .5 vdc at the icm. Check power at c100 and ign sw.
Old May 25, 2025 | 09:19 PM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Re: Tpi to carb
Unless you have all the parts for the carb swap, it's got to be cheaper and less work to fix the TPI. They're pretty simple and parts are plentiful.
what's wrong w your TPI?
Old May 25, 2025 | 09:21 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Tpi to carb
A short runner efi intake will mimic the car power curve and keep it functional for a dd.
Old May 25, 2025 | 09:22 PM
Engine: Lb9
Transmission: M20
Re: Tpi to carb
to lazy to diagnose, thanks for letting me tune for you 8 times and countless diagnostics for free and not wanting to pay a dime.
Z2EIGHT
May 25, 2008 05:28 PM
lilnach
Carburetors
Oct 3, 2005 12:22 AM
Rick King
Jul 12, 2004 07:07 PM
pardonme2711
Aug 6, 2002 10:19 AM
