88 formula tpi, no start
Old Jun 7, 2025 | 03:49 PM
John1975's Avatar
Engine: 5.0 and 5.7
Fuel pressure while turning ignition on Jumps to 50psi, then drops to zero when I hear the click. It will start after putting throttle to floor for 10 seconds or so, then dies. Starting fluid does nothing.... need ideas as to the problem.
Old Jun 7, 2025 | 03:51 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 88 formula tpi, no start
Your in clear flood mode, leaking fpr or injectors.
Old Jun 7, 2025 | 03:55 PM
John1975's Avatar
Engine: 5.0 and 5.7
that's what I thought other than starting fluid does nothing. Was driving with it and it suddenly died
Old Jun 7, 2025 | 03:56 PM
Engine: Lb9
Transmission: M20
Starting fluid does nothing because the plugs are fuel saturated.
Old Jun 7, 2025 | 03:57 PM
John1975's Avatar
Engine: 5.0 and 5.7
True
Old Jun 7, 2025 | 03:58 PM
John1975's Avatar
Engine: 5.0 and 5.7
I just took out my accel injectors because of a no start, put stocks back in and lasted a week.
Old Jun 7, 2025 | 04:08 PM
Engine: Lb9
Transmission: M20
If you don’t have fuel in the fpr vacuum line. I’d suspect a injector or two are leaking.
UncleSlamm
Apr 26, 2025 01:49 PM
fbodygirl
Sep 25, 2008 06:55 PM
Buck
Jun 20, 2006 05:08 PM
