Coil wire harness
Old Aug 20, 2025 | 11:07 AM
rtbrodeur's Avatar
Coil wire harness
I have a 97 5.7L tuned port engine with the coil that is separate from the distributor, mounted next to it. It has a grey connector and a black connector on the coil. One of the wires broke off the black connector and I need to replace either the connector or the whole harness. The harness is two-wire about a foot long. It goes from the coil to the connector on the Ignition Control Module in the distributor. Can anyone help me figure out where to buy the connector or harness?
Old Aug 20, 2025 | 11:39 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Coil wire harness
92 ?
Amazon Amazon
Old Aug 20, 2025 | 12:30 PM
rtbrodeur's Avatar
That's the one! Thank you. I discovered O'reillys has the connector on the coil end, but not the whole harness.
Old Aug 20, 2025 | 01:15 PM
Engine: Lb9
Transmission: M20
A better repair to replace the harness bs solder or butt connectors.
Nutro
Oct 31, 2023 10:55 PM
MrPink
Dec 13, 2012 07:36 PM
SVT_ETR
Nov 14, 2012 11:45 PM
reedwesd
Jul 1, 2009 08:57 AM
