Ignition coil to distributor
Am I correct in assuming that there is a 4 pin connector from body harness to the 4 pin side of distributor then there is a 2 pin connector from the distributor to the coil and that is it? Is there another connector that should be on the coil?
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Ignition coil to distributor
There are two connectors on the small cap hei divorced coil. The pink and white one is IGN+Crank and tach reference, respectively. The other one is the distributor sub-harness.
MrPink
Dec 13, 2012 07:36 PM
