Ignition Voltage drop while cranking
Old Jan 17, 2026 | 03:09 PM
Jack87iroc's Avatar
So I bought a non running 1987 305 TPI Camaro a couple weeks back. I've found that it's getting really weak spark and only 9v while cranking (12v key on) to the ignition coil. I've replaced the starter, ignition input wires fusable link, icm, ignition switch, ignition coil, spark plugs, and distributor pickup all both in a hail Mary attempt to fix the issue and also just so that they'd all be new parts. I also cleaned the c100 bulkhead connector and the ignition coil ground. After all of that changed nothing I completely bypassed the ignition input wire all the way to the ignition switch output. Even then I still have 9v while cranking. I'm pretty sure it's a ground somewhere or a power draw but I don't know from where and I don't have any good diagrams showing where to check. I don't know if anyone else has had the same issue or has any ideas but I figured I'd try to reach out for some help.
Edit: it seems like there's a misunderstanding, this is not a poor cranking voltage issue, instead however, it is poor voltage to the ignition system, ie: ignition switch, ignition coil, icm, ect. While cranking the engine and trying to start the Camaro, causing a no start.
Old Jan 17, 2026 | 03:30 PM
Re: Voltage drop while cranking
None of those things affects cranking voltage.
No. With the possible exception of, the negative batt cable connection to the block.
What's the voltage at the battery terminals themselves while cranking?
​​​​​​​attempt to fix the issue
What's the issue?
Old Jan 17, 2026 | 03:43 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
How cold is the battery and engine when you're cranking? It's pretty cold winter weather many places right now. If the vehicle is outside in the cold then lower cranking voltage is normal.
Old Jan 17, 2026 | 03:47 PM
Jack87iroc's Avatar
Originally Posted by QwkTrip
How cold is the battery and engine when you're cranking? It's cold outside right now and is normal to have lower cranking voltage in those conditions.
I'm using the battery out of my truck, the car didn't come with a battery, and the guy I bought it from had the same issue, thus why he sold it. My truck starts with this battery just fine, and the battery has about 11v while cranking, and the camaro cranks great and gets fuel, just not spark
Old Jan 17, 2026 | 03:50 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You still didn't answer the question.
Old Jan 17, 2026 | 03:52 PM
Then cranking voltage isn't the issue. Fugheddaboudit and move on.
the camaro
Not enough info. What year and engine? Is the engine original?
Old Jan 17, 2026 | 04:04 PM
Jack87iroc's Avatar
it's not cold related, my point mention the truck is that I put it into my Camaro, no start, and then put it in my equally cold truck and have it start up immediately. It's not weather
Old Jan 17, 2026 | 04:05 PM
Jack87iroc's Avatar
it's the ignition voltage WHILE cranking, not cranking voltage, sorry if that wasn't clear
1987 305 tpi
Old Jan 17, 2026 | 04:09 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You're too hard to help. I'm out.
Old Jan 18, 2026 | 11:32 AM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
Re: Ignition Voltage drop while cranking
if you can check the voltage draw on the wires that go to the coil. it sound like you have a damaged wire that is corded and restricting the voltage. look for a pinched or swollen wire. or one that has been chewed on by something rat/ mouse/ squirrel.
good luck
Old Jan 18, 2026 | 11:37 AM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
many times, the gorund cables on these cars get moved to another place.
this cuases what you are describing.
ive taken jumper cables and added temp grounds from the engine block to the chassis and then to the ground cable to help
z28m8
Jan 15, 2016 12:06 AM
TallTim
Jan 2, 2014 03:17 PM
lakeffect2
May 2, 2007 12:57 AM
Robert91RS
Jun 22, 2006 06:43 AM
