Tach slowly rising
Old Mar 10, 2026 | 03:28 AM
juldal's Avatar
Tach slowly rising
Hi I have an 86 Camaro Z28 with an Edelbrock Carb and a HEI distributor
There is a white wire on the TACH output from the HEI
My TACH meter when I put on ignition is slowly rising, and not getting any impulses. It just keeps rising slowly to beyond max
Do I need a new circuit board, or could it be something else.
Someone told me to have a new wire from the tach, to the HEI, but that seems quite hard, because there is a big plug with wires going on the back of the tach console, so theres not like any fixed connector to attach the wire.
Old Mar 10, 2026 | 09:36 AM
Re: Tach slowly rising
Most likely the tach itself is bad. Specifically, the little square circuit board mounted on the back of the actual gauge.
I'd recommend leaving the wiring COMPLETELY alone, to prevent the inevitable problems that inevitably result from butchering it.
Old Mar 10, 2026 | 10:29 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Originally Posted by juldal
Someone told me to have a new wire from the tach, to the HEI....
No.....just.........................no.
Instead, vvvvThis.
Old Mar 10, 2026 | 12:10 PM
juldal's Avatar
I have a colleague who knows a lot about electronics he said it might be the electro capacitor on the circuit. Because the gel inside dry out. A new one costs about 50.cents. so I will try and change it on the board.
Will post what happens..
Old Mar 10, 2026 | 12:23 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Tach problems are common on 3rd gen Camaros. This replacement tachometer circuit board is regarded as an excellent part and has two LEDs that verify the circuit board is getting power and RPM signal.
1982-89 Camaro V8 Tachometer Circuit Board, LEDs | Cajun Tach Shop
Without being there in person to diagnose the problem I can't guarantee your Camaro has a bad tachometer circuit board.
If you go to their homepage and scroll to the bottom they have a Contact Us section where you can send them a message or call them on the phone.
Old Mar 12, 2026 | 08:05 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Component-level replacement of printed-circuit components is not a commonly-seen skill. Maybe your electronics-knowledgeable friend would be a better candidate to do the job for you.
Old Mar 12, 2026 | 08:58 AM
juldal's Avatar
I am also educated in electronic it's just a long time ago but I know how to change a component. But your right. He has done it more often than me and more recently 👍
aussiesteve
Feb 9, 2022 10:48 PM
stalkier
Aug 7, 2015 04:49 AM
billybob6110
Oct 4, 2010 01:44 PM
dmp7777777
Aug 1, 2004 11:10 AM
sixbanger
Mar 4, 2004 08:29 PM
