MAF 1989 TPI Formula 350
Old May 11, 2026 | 03:56 PM
Don Fetherolf's Avatar
Car: 1989 Pontiac Firebird Formula 350
Engine: 5.7 TPI
Axle/Gears: 9 Bolt 3:27
Hi,
Question for the group: On my 1989 Formula 350 TPI with key on engine off my MAF shows 5 gms with my scan tool (OTC 4000e) and my laptop using TunerPro RT.
Is this normal? I search the internet, my factory service manual & on here and cannot find anything stating on what it should read with engine off.
My car at idle (engine at 170 deg f) was showing MAF of 10-12 gms at idle (675 rpm) and running rich. MAF was 10.31, BLM was at 108 and INT at 81 so ecm was trying to lean it out.
So I started checking my MAF circuit and found I had 15 ohms resistance on the black wire (MAF pin B to ecm pin A11). So checking I found some hack probed through
the wire insulation at the connector on all the MAF wires. I ended up installing a new connector with terminals and 12" wires and retested and now at an idle of 675 my MAF is 5 to 6 gms. So my repair fixed the rich idle condition.
But with key on engine off MAF still shows 5 gms! So does the ecm automatically have the MAF 5 gms for start up?
Old May 12, 2026 | 09:06 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Re: MAF 1989 TPI Formula 350
Well diagnosed.
Old May 24, 2026 | 07:36 PM
DanielCollins35's Avatar
On the Pontiac Firebird Formula 350 TPI (1989), seeing around 5 g/s with key on engine off is actually pretty normal for that system. Most GM MAF setups of that era don’t truly read “zero” KOEO — they often sit in a small baseline range due to sensor calibration and how the ECM interprets airflow voltage at rest.
Your idle numbers before the repair (10–12 g/s with rich BLM/INT correction) definitely point to a signal issue rather than true airflow. The fact that you had resistance in the MAF ground/return circuit explains it perfectly — that kind of added resistance will skew the frequency/voltage signal and make the ECM think more air is entering than actually is.
After fixing the connector and dropping to 5–6 g/s at idle, plus more normal fuel trims, that’s exactly what you’d expect from a healthy reading on these systems.
Old May 25, 2026 | 06:32 AM
Engine: 5.7 TPI
Thanks for the answer. I did not have another TPI car to compare the readings and could not find anything for koeo readings in my oem service manual.
2kickassbirds
Apr 12, 2008 05:45 PM
1987earthquake
Dec 21, 2006 05:39 PM
SSprayd
Oct 15, 2005 07:57 AM
DannyT
Jan 2, 2004 06:37 PM
NOSFEDGTA
Oct 1, 2002 10:36 AM
