VATS Key
Old Jun 17, 2026 | 02:03 PM
TimRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
VATS Key
I’ve got the resistor to bypass the VATS system. I’m assuming that once this is done, I can use a pre VATS GM ignition key without a resistor pellet. Can anyone confirm this?
Old Jun 17, 2026 | 02:05 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: VATS Key
Removing the wires at the bottom of the column and inserting the appropriate resistor on the body side not column side bypasses the key reader. So yes a different cylinder or non vats pellet key can be used.
Old Jun 17, 2026 | 02:38 PM
scottycamaroz28's Avatar
Car: 89 PONTIAC TRANS AM
Engine: 5.0 TPI
Transmission: Stock 4SP 700R4
Axle/Gears: 4TH GEN 3:23
Re: VATS Key
My vats system is bypassed now because under the previous owner someone tried to steal the car and broke up the ignition. Its one of the main reasons I got the car so cheap because he could not find anyone willing to work on putting the new ignition in. I simply bypassed the vats, car started right away and I drive away within 10 mins and the guy stands there looking like an idiot. But because someone tried to steal the car the ignition was pretty messed up. I got a new gm normal style ignition with classic square key and all is well.
pete2833
Apr 17, 2025 01:11 PM
thebandit92
Mar 17, 2007 09:16 AM
yellow73bb
Nov 29, 2004 08:04 AM
1991 RS 305
Jun 28, 2003 04:34 PM
CALIROCZ28
Aug 9, 2002 11:37 AM
