VATS Key ?
Old Apr 16, 2025 | 06:42 PM
pete2833's Avatar
Car: 1986 Camaro Iroc
Engine: 5.0 TPI
VATS Key ?
I’m restoring an 85 Iroc with 71,000 miles on it.
I know the VATS key is not on an 1985 but I only got 1 set of keys with the car. The key is a VATS key. Any ideas ? Did someone just cut a VATS key or is there a way I can check to make sure I have no VATS ?
Old Apr 16, 2025 | 06:48 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: VATS Key ?
I'm guessing someone just cut a VATS key.
Old Apr 16, 2025 | 06:49 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: VATS Key ?
If it has the stock VATS then you should find a two position connector under steering column. A picture can be seen in this thread,
https://www.thirdgen.org/forums/elec...pass-vats.html
if not, then the pellet is inconsequential.
Old Apr 16, 2025 | 08:01 PM
pete2833's Avatar
Engine: 5.0 TPI
Re: VATS Key ?
Thanks. I will look and see if I can find anything.
Pete
Old Apr 17, 2025 | 12:40 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: VATS Key ?
Another way is to have a copy cut of the key without a chip and see if the car starts.
Old Apr 17, 2025 | 11:35 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: VATS Key ?
Based on the hundreds of threads posted about it on this site, and as big of a PITA as that VATS system is for owners of 3rd gens with it, I can't even imagine someone retrofitting it to an '85.
....but I've also learned to never say, 'never' on this forum; stranger things than that have been reported here.
Old Apr 17, 2025 | 01:11 PM
pete2833's Avatar
Engine: 5.0 TPI
Re: VATS Key ?
I was thinking the same thing.
was wondering if the steering column was switched out at some point. I know the wiring would have to be connected as well.
Lurbie
Sep 14, 2017 07:51 PM
blaze15301
Apr 24, 2017 11:13 PM
graysmoke
Mar 10, 2014 03:31 PM
yellow73bb
Nov 29, 2004 08:04 AM
Zuckuss88GTA
Jun 17, 2002 10:39 PM
