headlights not working
Old Feb 3, 2002 | 02:28 PM
wa90formula350's Avatar
OK guys this is for my 94 Wrangler but the light switch and hi beam wiper switch are the same as my 90 Formula, thought I'd see if anyone has an idea, the Jeep forums suck. Lights are good replaced one a week ago. Everything works except head lights, parking, tail etc., fusable link in the engine compartment was good and that is the only fuse involved that I know of, pulled the headlights switch out and checked, the insides were good. The parts guy told me that it could be the high beam/low beam on the wiper, turn signal switch on the stearing column. I really dont want to tear into the the stearing column for no reason, unless someone else here has had the same problem and it was the switch on the column. Again sorry its not a Firebird problem, same parts though.
Rob
1990 Formula 350
SLP headers, Flowmaster
Old Feb 3, 2002 | 11:32 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
The tail lights shoulden't have anything to do with the head light's high/low beam switch. The switch went bad on my Z last summer and the tail lights still worked.
-Matt
Old Feb 4, 2002 | 07:15 PM
I'm sorry, I dont write clear, the headlights dont work, everything else is fine, was wondering if the high/low beam on the column could be the cause as everything else checks out. And thank you to Flash for replying
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Fronzizzle
Aug 19, 2015 01:36 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
stalkier
Aug 13, 2015 12:59 PM
