Alternator die down
Old Feb 3, 2002 | 11:47 PM
IROCBandit's Avatar
Alternator die down
My alternator went out on my a few weeks ago, not fun cause it shut my computer off and my car ran like s***. so i went down had the alternator tested and it was crap so they gave me a new one. bolted her on and it seemed fine but it still has die down about as bad as the old alternator. im always going in the red whenever i come to a stop. can anyone explain why that is? the best i can ever get out of it cruising is 11, ive never seen it go higher on the gauge.
Old Feb 4, 2002 | 12:08 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I'm sure you know this but, make sure all your contacts are clean & you've got a good battery-chassis ground & motor-chassis ground.
You may want to look into getting some new cables if that doesn't help. I replaced the ground on my 'bird with a new 4ga ground to the block & and an 8ga ground to the chassis to eleminate my problem since they were both in pretty bad shape (internal corrosion).
Old Feb 4, 2002 | 02:24 AM
914Mula's Avatar
Car: 91' Formula
Engine: 383CID
Transmission: t-56
Axle/Gears: 4.10
Did you disconnect your battery before hooking it up?....I bought a new alternator a couple of months ago and 2 days later it was already out . I replaced it with another one b/c it was under warranty and it is still working fine. Some are just peices of crap!
Old Feb 4, 2002 | 04:44 AM
greg_pl's Avatar
Car: IROC 5,0 TPI '88
Transmission: auto
alternator
HI !
You should upgrade Yor alternator or change
I recommendet www.alternatorparts.com
very OK and cheap and fast ship
( 4 day to Poland !!!!!!! )
I repleace my alterantor on CS130 "Iceberg"
and all is now OK - every time is 13,5 V !!!!!!
Regards!!!!!
Old Feb 11, 2002 | 08:21 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
call and talk to these guys they know alternators inside and out http://www.powermastermotorsports.com/
Old Feb 12, 2002 | 10:48 AM
mtccl's Avatar
If you have a V-belt setup make sure the belt is good and tight. If it is a serpentine then put on a new belt after checking the other stuff. Good Luck!!
Old Feb 14, 2002 | 08:13 PM
Hellraiser's Avatar
Don't forget, you should really charge your battery on a proper charger before (or at least soon after) installing a new alternator.
Alternators in cars aren't really meant to recharge a dead/dying batter - only maintain a proper charge while supporting the accessories. Putting a dying battery on a *** alternator overworks it, putting too much stress on the internals.
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Giocio
Oct 1, 2015 12:20 PM
Luigytico09
Oct 1, 2015 08:46 AM
