Have Two Electrical Problems Need Help Please?
Old Feb 8, 2002 | 11:47 AM
EFF26's Avatar
Car: 1991 firebird
Engine: lo3 305 TBI
SOMETIMES I WILL GO TO START MY CAR AND OUT OF THE BLUE IT WON'T EVEN CRANK OR TURN OVER. I HAVE CHECKED AA CONECTIONS ,BATTERY IS GOOD . BUT AFTER IT SETS A WHILE IT WILL FIRE RIGHT UP .COULD IT POOSIBLY BE THE STARTER OR THE SOLINOID. MY OTHER ? IS SOMETIMES MY HEATER BLOWER MOTOR WILL WORK AND IT WON'T OR I CAN BEDRIVIGAND IT WILL COME ON .COULD IT BE THE RESISTOR.
THANKS RANDY EFFLER
91 FIREBIRD
Old Feb 14, 2002 | 02:20 PM
rtstone79's Avatar
With your starting problems the first thing i would check is your solenoid. Also check for a short in your ignition circuit possibly a fusible link. I had that problem with my jeep. As for your heater blower cutting in and out, i had the exact same problem with my GTA. My problem was that there is a bolt coming out of the back of my driver side head, it is used as a ground for the heater as well as a few other things, the nut on the bolt had backed off giving a bad ground. So sometimes the heater worked sometimes not. I tightened the nut back up and used some lock tight on the threads. No problem since.
Hope this helps.
Old Feb 15, 2002 | 11:08 PM
Don Christensen's Avatar
Car: 1989 Formula - Red
Transmission: 700 R4
Axle/Gears: 3.73 Posi
Could also be a relay on the heater problem
There is a realy by the heater blower motor that is often the problem too!
Old Feb 15, 2002 | 11:11 PM
Typo - I meant RELAY. Also, on your starting
problem, you could have a bad starting relay on the VATS (Vehicle Anti Theft System), as well as a bad VATS senser.
Good luck
Old Feb 16, 2002 | 02:14 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Tighten up the bolts on your starter.
toones
Jan 6, 2016 06:00 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
