Fusable LINKS ?
Old Feb 25, 2002 | 06:42 AM
Marc van den Broek's Avatar
Fusable LINKS ?
Well here is marc again from holland......
I have a stupid question i think ?
- what is a fuseable link ?
- Can i replace it with something else than the orginal but with the same value ???
can anyone tell me all about it.......
thankx....
greetz Marc from holland
Old Feb 26, 2002 | 10:11 PM
cfabe's Avatar
Fusible links are basically thick fuses. They provide protection from massive short circuits (I blew one when the wires coming from the starter burnt on the exhaust and shorted). They are sold in gauges, not amps. I've heard that you should use a link 2 gauges smaller then the wire you're protecting. You can replace them with fusible link that should be available at an auto parts store, or you can get replacements that will already have the connector for the starter bolts crimped on.
The reason for using these instead of fuses is they have less resistance and cause less voltage drop under load.
Fanatic1074
Oct 3, 2022 05:57 AM
3rd gen money
Oct 11, 2019 09:57 PM
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
