Oil and Temp Lights
Old Mar 12, 2002 | 09:47 AM
cooperman's Avatar
Oil and Temp Lights
Hi all,
I don't get my oil and temp idiot lights coming on when I turn on the ignition. All guages are OK and all bulbs are OK.
Problem seems to have started when I removed the stock radio for repair. Stock radio went back in OK. Are there any wires in the radio housing that could have been disturbed...I've looked and can't see any thing wrong
Any ideas anyone??
thanks
Paul Cooper
Old Mar 13, 2002 | 02:01 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
When you turn the ign on, only the oil light should come on. The temp light should only come on when the key is in the "start" position. If they do not function as they should, check the gauges fuse. If that is OK, try shorting the wire at the oil pressure sender to ground with the ign on & the oil light should come on. If it does come on after shorting the wire to ground, then replace the oil pressure sender.
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Navy8125
Aug 21, 2015 09:32 AM
bamaboy0323
Aug 15, 2015 07:20 AM
Omega
Aug 10, 2015 12:46 PM
