Inst lmps fuse keeps going
Old Mar 12, 2002 | 04:37 PM
bklucas12's Avatar
I posted this before and I thought I had it figured out, but when i put my fuse in the inst lmps it keeps going out, here is the story
bought a new cd player put it in, when it was all said and done when I put my lights on my dash doesnt light up. so I posted on the board... I checked my fuses before but I guess I wasnt looking at the right one, someone on the board told me to check my inst lmps fuse, so I did. it is a 5 amp fuse... so I checked and it was blown, well its 2 weeks later and I finally got another fuse... put it in and it blew instantly, put another in and it blew, tried it 3 times... finally I was pissed, so I tried a 10 amp fuse, blew that, tried another one and it didnt blow, took it out and put my 5 amp fuse in and it didnt blow but the dash still doesnt light up... did I screw something up bad when I put that 10 in? or is there another reason, also why did the 5 keep blowing? thanks for the help
Old Mar 12, 2002 | 04:59 PM
2vmodular's Avatar
cut the grey wire on the radio receiver harness and tape the two ends with electrical tape. does the fuse still blow when parking lights are turned on?
Old Mar 12, 2002 | 05:17 PM
bklucas12's Avatar
Where is this gray wire? if you could explain just a little more that would be great, thanks again
Old Mar 12, 2002 | 05:47 PM
GregN's Avatar
You blew the triac in the dimmer control module by putting the 10A fuse in there. Check out this thread. Same problem, fairly simple solution if you know how to solder. I'm having the same problem with my Berlinetta but my electronic modules are different so I'm having to track it down differently. You can find the part at radioshack.com. T?he stores don't carry them any more. Hell, the electronics stores in my area don't even have one.
Old Mar 12, 2002 | 06:59 PM
2vmodular's Avatar
pull the radio out of the dash. on the dashboard electrical harness there will be a T shaped junction where the radio ties in. somewhere in this bundle of wires, there where be a gray colored wire that runs to the back of the radio.
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
AmorgetRS
Sep 28, 2015 09:33 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
