Ignition Setup
Old Mar 13, 2002 | 01:54 AM
da BEAST's Avatar
Car: 99 F350 Dually 97 Chevy Venture 97 Honda Accord 89 Mercedes Benz 190 1987 TRANS AM GTA
Engine: Brand new 350 Crate motor
Transmission: Beefed up 700R4
Ignition Setup
What is a good ignition and coil setup for my 87 GTA. I like the MSD but wondering which one the 6A or the 6AL. Also which is the best coil that will work with this box?
Old Mar 13, 2002 | 07:57 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The only difference between the 6A & 6AL is the L has a rev limiter & costs about $50 more. If you want a rev limiter get the 6AL. I use a MSD 6A, MSD Blaster coil for HEI, seperate coil with MSD's adapter harness. It was easy to install & I didn't have to cut the factory harness. I called Summit & they looked up the numbers for me.
Bubbajones_ya
Jul 6, 2024 08:32 PM
MM2Robinson
Oct 1, 2017 09:16 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
customblackbird
Oct 1, 2015 04:30 PM
Jlanz55
Sep 6, 2015 02:35 PM
