Pass-key decoder module.. Where??
Old Mar 13, 2002 | 12:20 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Anyone know where it is located??
It is connected through the starter relay...
Approx. area?
Old Mar 13, 2002 | 01:22 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The module is located at about the center of the dash - kind of up & behind the radio & is difficult to access. The dash must be disassembled and pulled back to reach it. It controlls the start enable relay and sends a fuel injector enable signal to the ECM.
Old Mar 13, 2002 | 01:33 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
crap.... Thats not good..
Thanks...
:hail: :lala:
Old Mar 13, 2002 | 01:49 PM
What is the problem with the car? No crank? No start, but will crank?
Old Mar 13, 2002 | 05:12 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
no crank, no click, no start, no voltage to the gear selector switch.
After attempting to bypass the VATS system, by wiring in a 1.866 kilo-ohm(the same as the key) resistor to the connector under the dash.. the security light seems to be stuck on... Got any idea on how to reset it?
Old Mar 14, 2002 | 10:11 AM
If the security light stays on when the ign is turned on, instead of coming on for a few seconds & then turning off, then the VATS module is reading an incorrect resistance from the key resistor sense lines. If the security light does not come on at all when the ign is turned on, then the VATS module is reading a short (zero ohms), or an open circuit across the key resistor sense lines.
Old Mar 15, 2002 | 10:24 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
yea....
The security light wasn't coming on at all.
I did check the codes on the diag. circuit and got a code 46 (VATS).
I got out the Ohmmeter and checked the resistance from the lines going to the lock cylinder and got an open circuit with the key in the ignition. So I went out and bought some resistors and matched the resistance of my key with them.
Bypassing the lock cylinder fixed the problem.
Thanks for the help!
Elephantismo
Feb 13, 2019 12:51 AM
F-body-fan
Sep 24, 2015 08:29 AM
dbrochard
Aug 30, 2015 05:56 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
TerryK21
Apr 15, 2001 01:34 AM
