Can't find my fuse for fuel pump
Old Mar 16, 2002 | 11:28 AM
Cornflakekid's Avatar
I can't find my fuel pump/oil pressure switch sender fuse?
It's a in-line fuse (20A) that runs off a orange wire.
It's on a 1991 RS Camaro 3.1 V6.
Old Mar 16, 2002 | 02:42 PM
dave's92Z's Avatar
fuse location
On my 92 the fuse is located next to the batt on the fender. the manuel said it was located in the fuse block but I found it after hunting forever. hope this helps
Old Mar 16, 2002 | 03:47 PM
Thanks I'll take a look!
Old Mar 16, 2002 | 03:56 PM
THANK YOU THANK YOU THANK YOU!
I found it right where you said. You just saved me alot of time!
Old Mar 16, 2002 | 05:54 PM
dave's92Z's Avatar
No problem. I had to find mine cause my car still wont start and i am trying to trace everything from my ECM to see if it is my ecm.
Old Mar 16, 2002 | 07:51 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
As far as I'm aware, all thirdgens with electronic fuel pumps in the gas tank have that fuse by the battery.
Old Mar 17, 2002 | 01:24 AM
Jza's Avatar
Jza
That fuse is the ECM fuse.
Old Mar 19, 2002 | 10:57 PM
Don Christensen's Avatar
Car: 1989 Formula - Red
Transmission: 700 R4
Axle/Gears: 3.73 Posi
Some are by the fuse-block.
The fuel pump fuse for my wife's 89 Formula (World's Fastest School Board Member) is located one half inch in front of the fuse block, and was covered by black tape. It took me 3 days to find it!!!
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
