starter kill relay wiring
Old Mar 25, 2002 | 03:43 PM
mudaholic's Avatar
im just finishing up installing this alarm, but im not exactly sure how to hook up this relay.. the attached image is the install guide's explanation.. i believe the primary ignition is pink, and the starter wire is yellow.. how exactly do i hook it up tho? what i interpret is to splice the yellow relay wire into the pink ignition wire (with a t-connector or something like that), cut the yellow starter wire and connect the one end to the green relay wire, and the other end to the black relay wire... is that correct? thanks guys!
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
Dialed_In
Aug 20, 2015 01:45 PM
