Lights go up lights stay up and don't go down
Old Mar 25, 2002 | 07:13 PM
Stormshadow GTA's Avatar
When i flip my lights up they go up fine but when i turn them off they stay up.What's up?
Old Mar 26, 2002 | 10:18 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I have a similar problem, but they go down if i push on the button hard. I have changed the switch but it still does it. I have no idea what could be wrong.
Old Mar 26, 2002 | 10:38 AM
mtccl's Avatar
Sounds like you have a bad modulator. That was my problem. Replaced off E-bay for $10.00.
Attached Thumbnails Lights go up lights stay up and don't go down-modulator.jpg
Old Mar 26, 2002 | 11:33 AM
Omega's Avatar
Engine: LS1 / LS3
Stormshadow GTA:
Are you refering to mtccl or me? Could my problem be a syptom of a bad modulator also?
Old Mar 26, 2002 | 11:46 AM
MikeS's Avatar
Interesting.... I have Omega's problem too. I've never messed with it though since it isn't really a big problem at this point. I just figured I had some bad contacts in the switch. Maybe that's not so though, since a new switch didn't fix it for you.
Old Mar 26, 2002 | 02:48 PM
mtccl's Avatar
All of you who have this modulator, open the hood with the lights in the offending position and press on the front of the modulator. For instance, if your lights stay up after you turn the switch off, press on the modulator body. See if the lights go down. If they do then it is your modulator. The contacts inside go bad. Good Luck!!
Ghettobird52
Jul 5, 2024 11:18 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
