Light Over My Heat/ac Controlls
Old Mar 26, 2002 | 12:25 PM
Jeff Morgan's Avatar
I have a 1982 Pontiac Firebird SE. Last weekend the light over my heat and A/C controller went out. Does anyone know how I can get to the bulb? Your help is appreciated. Also, is there a fuse that operates my rear Defogger? Mine doesn't work, but the light indicator works.
Thanks in advance for your help.
Jeff Morgan
Old Mar 28, 2002 | 12:42 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The tiny bulb (can't recall the number) above the A/C controls is available from GM, and Pep Boys.
Check the wire connections @ the hatch lifts for the defroster & measure for 12 volts relative to ground @ the driver side wire with the engine on & the defroster switch on. If there is no power there, then the problem is upstream from there.
The 35 ampere power accy circuit breaker supplies power to the defroster & the 10 ampere gauges fuse supplies power to the electronics in the switch.
Old Mar 28, 2002 | 12:47 PM
Thanks Tim. I'll check it out this weekend. Oh, by the way. How do I get to that tiny bulb?
Thanks!
Jeff Morgan
eightsixseven
Dec 16, 2024 01:50 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
