Cruise Control Switch Wiring
Old Mar 27, 2002 | 01:03 PM
tpsierra's Avatar
All the cruise schematics say there are 4 leads to the cruixe switch, but all the levers I can find only have a 3 conductor wire with them, usually with a flat connector with a slot and colors of orange, black and blue.
My car has factory cruise, and I could not find the connector to the lever, so I wired directly from the switch to the servo, so I have accelerate, that's all. I know where the module is, and I finally found a connector, but it is a 4 wire, pink;black, grey, grey/blackand dk blue. It is a 2 sided connector. Is there a special type cruise switch? All the ones I've found are out of sedans, not camaros.
Old Mar 27, 2002 | 01:34 PM
Berlinetta's Avatar
hey, i can actually help you. I just installed all factory cruise components on my car and you're right, the column switch has four wires coming off of it, and the connector should come out at the floorboard near the firewall out of the steering column. There's a crapload of wires down there so you might have to move stuff out of the way. The connector you found with the four wires is the one that should be on your car. Hope this helps
Old Mar 28, 2002 | 02:37 AM
tpsierra's Avatar
figured it out, older levers are 3 wire, got one out of a S-10. everything great. turns out you fcan separate the end 1" of the lever, so you can change wiper type and wash levers, it is a glue joint that I successfully separated with needle nose pliers after popping off the set button.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
