Headlight Door
Old Apr 2, 2002 | 09:40 PM
vmax95's Avatar
Headlight Door
I have an 89 Firebird, the drivers side headlight door is starting to hesitate when turned on. Is there a repair for this , or do you have to replace the whole motor ?
Old Apr 3, 2002 | 03:01 PM
89BlackBirdKid's Avatar
your bearings are probaly gone. The gear that the motor turns for the doors have bearings that are plastic. I just fixed mine and replace it with 7/16 steel bearings and they both work great. Take out your whole headlight assembly. You'll have to take the headlight out because 2 of the bolts are under there and two are near the top. Disassemble(sp) the motor not from the top by the **** but your see the side where the gear is. Just tear into it and you'll see what I mean. Hope I helped some.
Old Apr 3, 2002 | 08:55 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
vmax,
Try this and see if it helps:
http://home.talkcity.com/ProjectPl/o...dlight_fix.htm
Try to ignore the stupid pop-up. Free web space, you know.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Buggy Disaster
Sep 17, 2015 05:12 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
