tach sticking
Old Apr 8, 2002 | 11:32 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
tach sticking
ok what would cause tachometer to be staying at around 2 or 2500 rpm after firing up engine, and soemtimes not doing that and sometimes unsticking and working fine ?
thanks for anything
Old Oct 15, 2006 | 12:35 PM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
i'm actually having the same problem. When i rev it up the tach kinda jumps, but you have to tap the gauge to get it to go back down. So if you find out a solution let me know. Thanks
Old Oct 15, 2006 | 03:43 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Is this the factory in dash tach or an aftermarket tach? I had a similar problem with an aftermarket tach and after rechecking all the wiring to be sure it was tight and connected properly I decided the tach was bad, replaced it and havent had a problem since.
Old Oct 15, 2006 | 05:35 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
also
when i first got my car the tach would jump around, sometimes sticking at certain spots, and jumping in sporadic bursts rather than smoothly
all it needed was a good cleaning in the cap and a new rotor.
ignition modules will also cause that, but there will usually be drivability problems associated with it too
$750 L98
Feb 1, 2025 02:25 PM
Drone358
Sep 28, 2015 04:55 PM
Eric-86sc
Sep 28, 2015 11:37 AM
ndndndnd
Sep 28, 2015 08:00 AM
TrevinE
Sep 14, 2015 03:20 PM
