Alternator, Power windows, Engine fan, Heater all dead
Old Apr 9, 2002 | 10:35 PM
TAZmndvl's Avatar
I have an '88 Camaro with a 305 TBI and I have no clue what could cause the alternator, the power windows, the ingine fan, and the Heater to quit on me at the same time? I tried replacing the alternator, that didn't help! The repair manual that I am using has a wiring diagram but does not show where all these might be connected together. Any help would be appreciated. Thanks!
Old Apr 9, 2002 | 11:11 PM
d_rtis's Avatar
thats a little too much, I dont know were to start. The only place they all meet is the battery. Need more info, what happened when the new alternator was put in? Did it start?Any problems before? Check fuses? Were the window motors acting up before?
Old Apr 10, 2002 | 12:24 AM
TAZmndvl's Avatar
All the fuses at the fuse block are good, the car starts and runs fine, and no I didn't have any problems with prior. It all just went, all at once. Thier was no change when I put the new alternator in, alt. guage reads 8 volts. I did check the wiring at the alternator and found that it was not getting power to the alternator field wire so I used a short wire and ran it from the battery to the field wire and everything suddenly worked again. I could leave it at that, but would rather compleate a proper repair.
Old Apr 11, 2002 | 11:15 AM
MX265
Guest
Posts: n/a
Have a look at this post and see how it ended. this may help:
https://www.thirdgen.org/techbb2/sho...threadid=98528
Old Apr 14, 2002 | 05:40 AM
iroctpis's Avatar
I had a similar problem years ago, windows, blower fan, wouldn't work, so I dropped the steering column down a little and took the ignition switch off and apart and a spring had sprung out of its compartment and was touching other metal, I replaced it and everything worked fine.
Old Apr 15, 2002 | 11:01 AM
TAZmndvl's Avatar
:hail:
Thank you for the insight, I checked my ignition switch and found part of it was melted. I don't know if this is the only source of the problem, but I'm sure that it is a major contributor. I plan on replacing it as soon a finances allow, I'll let you all know how it turns out.
Old Apr 15, 2002 | 02:18 PM
mtccl's Avatar
You'll also want to check your inline fusible links between the starter and battery. Search for fusible link and you'll find the information on how they work and where they are. Good Luck!
Old May 6, 2002 | 04:53 PM
TAZmndvl's Avatar
Replaced the ignition switch yesterday and POOF!! everythings working again. Thanks to all who posted, the advice was very helpfull. :hail:
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
