drl wiring question
Old Apr 10, 2002 | 09:52 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
drl wiring question
how can i wire up my front turn signals so that they are on when the car is on but the turn signals still work?
thanks
brady
1992 RS
Old Apr 10, 2002 | 10:07 PM
TheCamel's Avatar
you will need a dual filament bulb like your brake lights Bulb 1157 or 1034 and a dual filament harness for each side, hook your turn signal feed wire into the bright side, and your other side to the constant ignition power.
Other than that you cannot do it because the signal wire always gets its feed from the turn signal switch, and the reason it works with the tail lights is the complicated wirirng that is run through the turnsignal switch and the brake lights.
Sean
Old Apr 10, 2002 | 10:20 PM
where can i get dual filament harness and bulbs
thanks
Old Apr 11, 2002 | 05:43 AM
Jza's Avatar
Jza
First of all, the front turn-signal bulbs are dual-filament bulbs. Why do you think they're on when your lights are on, and get brighter when your turn signal is on?
And secondly, you can do it. Check out Willie's cars if you wan't proof. His DRL circuit was designed by Tim Burgess. Plus, they work like DRLs should, which is the bright filament is on during the day and flash on and off with a turn signal; and when the headlights are activated, the dim filaments come on with the brights flashing on turn signal.
Ask him nicely and maybe he'll post the schematics for it. He snail-mailed them to me, and I don't have a scanner, so that's why I can't just go ahead and post them here myself.
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
