FS: 87iroc 305 TPI (houston, tx)
I just took out the engine from my 87 iroc z. The car ran but had a knock and as I expected it has two spun main bearings right next to each other. All that needs to be done is probably to change the bearings and maybe get the crank turned and you're good to go.
I will include all the parts including the harness (if I can get it out in one piece), intake, TB, rails, block and heads still partially assembled, unassembled pieces are in labeled plastic baggies. I just took it apart to make sure I knew what was wrong. Everything else appears in good shape, no visible cracks.
I don't need most of the stuff since I'm swapping in a carbed motor.
I'd like to get 600$ picked up from NW houston, TX.
Make any reasonable offer I'm just throwing that out there as a starting price.
Originally Posted by ohiothirdgen
how much for the complete tpi computer harness everything?
anyone correct me if my prices are outrageous. I'm not getting enough replies!
Originally Posted by Aceprowler
Ditto
for the complete set up (everything + harness) I'd think 250$ or so would be a decent price?
okay 250$ gets the fuel rails, TB, plenum (or whatever its called), runners, the manifold base, harness, and even the lil plastic intake if you want it. I'd give you injectors too but I can't guaruntee whether or not they are good. Probably needed a good tune up. I think it's a decent price but I'll take any offers.
ambainb
Apr 25, 2016 09:21 PM
Sanjay
Aug 12, 2015 03:41 PM
150 for the tpi intake manifold runners and throttlebody
