350 for rebuild
Old Jun 26, 2006 | 04:48 PM
djtricia's Avatar
Car: 1986 Z-28
350 for rebuild
I have a 5.7 1 piece rear main seal engine. It was a remanufactured engine that came in the car I bought 18 months ago. The guy told me it had about 20,000 miles on it. It had a ticking sound when I bought it. Thought it was the lifters. replaced them but it didn't change anything. I've put 10,000 miles on it since then as my daily driver. The other problem I had was when it was hot at a light in gear the oil pressure would drop to 10lbs. I pulled the engine and am replacing it with something else. The engine comes with a mild cam, no intake or carb. I'm asking $200.00 and pick up only. Also it's a 4 bolt main block.
SOLD, THANKS.
Old Jun 29, 2006 | 08:46 AM
djtricia's Avatar
Car: 1986 Z-28
Any one need an engine to build up?
Old Jul 3, 2006 | 11:51 AM
djtricia's Avatar
Car: 1986 Z-28
4 bolt main
Price went up from the original $125.00 because I found out it's a more desirable engine.
Old Jul 3, 2006 | 05:33 PM
djtricia's Avatar
Car: 1986 Z-28
roller block too
I pulled the intake off to go on my other engine and found out the block has the mounting bosses for the roller cam spider that holds the keepers in place.
Old Jul 4, 2006 | 03:10 AM
darth442's Avatar
Car: '92 RS
Engine: 305 TBI
What kind of ticking sound?
Are we talking rod knock or spun bearing? Basically do you have any reason to believe the lower end needs more than the usual .10/.10 on the crank and .30 on the cylinders? Also, has it been bored before and if so how much? If not I'm game.
Old Jul 4, 2006 | 08:32 AM
bird355's Avatar
still for sale??
$200 for long or short block. might be interested. what heads if long?
Old Jul 4, 2006 | 11:22 AM
djtricia's Avatar
Car: 1986 Z-28
long block
I pulled a head off. The block has been bored 30 over when it was remanufactured. As far as whether the noise is from a spun bearing or rod, I don't know. I am having disc problems with my back and am not going to tear the engine apart any farther. The engine comes as a long block, no carb, intake, dizzy, water pump, balancer or exhaust manifolds. The heads are 191's.
Old Jul 7, 2006 | 04:11 PM
djtricia's Avatar
Car: 1986 Z-28
good core or more
ttt
Old Jul 9, 2006 | 02:13 PM
calobs87irocz's Avatar
Car: 87 Iroc Z, 70 & 71 Camaros, 79 Z-28
Engine: 350TPI, 350, 355, 355
Transmission: 700R4, TH350, TH350, TH350
Axle/Gears: BW3.27, 4.10, 3.73, don't know yet
PM sent
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Magman
Sep 13, 2015 08:43 AM
fbirdroller
Sep 2, 2015 10:27 PM
transamgta87
Sep 1, 2015 07:07 PM
Eric-86sc
Aug 24, 2015 09:01 PM
