Cleaning out garage--double humps, posi, 10 bolt, 600dp, etc...
Old Jul 6, 2006 | 09:02 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
Got a few parts layin around that I wanna get rid of.
Flywheel--NEVER USED!! I bought it not knowing it wouldnt fit a stock T5 Bellhousing. 168-Tooth, 12.00 in. Diameter, Steel, External Balance. Paid $200 new, will sell for $100+ship.
Double hump heads--w/ acc holes. I forgot to get the casting # when I was in the attic, Ill get it if someone is interested. THere is a small chip around one of the valve guide bosses, not sure what it even is. Also missing 1 rocker stud. Paid $100 but never used them I ended up gettin some Vortecs. $50+ship, might be better to pick up because of the weight.
Dual inlet air cleaner-- wouldnt fit over my holley, looks like an L69. Def. needs a good cleaning. $15+ship.
Posi carrier USED-- came out of an LT1 Camaro, stock gear was 2.77. Pinion nut came loose on a customers ride and slightly rode up onto posi case (see pic). Posi itself was working fine when removed, customer just wanted to go ahead and replace it. Sold to me for $100, will sell for $40+ship.
Aftermarket Hi-Rise spoiler-- fiberglass, has very small crack on one pillar (see pic). I put a little fiberglass resin over it to try and help it, but its nothing serious. painted in black primer now, will sell for $50+ship
Holley 600 double pumper (mech. secondaries). Model 4150 (4776). Just replaced power valve, everything else stock. Started pouring fuel out of secondary relief hose, but never looked into it. Im pretty sure its the float, but I never fooled around with it. Was rebuilt about 8 months/20 miles ago, just took off the car about a month ago. $60+ship.
3" Magnaflow Catalytic Converter--never used!! 3 way converter, summit part# MPE-94109. $30 shipped.
Dynomax Super Turbo muffler-- 3" inlet/outlet center/offset that I had on the car for about a month. summit part# WLK-17769 , $40 shipped.
I also have my Camaro for sale. It is listed in the cars for sale section. Sale is pending but not definite. Asking $5000 obo, see post for details/specs.
Email or PM me for shipping quotes, questions or anything else. Thanks for looking!!
PICS HERE
Old Jul 6, 2006 | 10:32 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
pics of aircleaner?
Old Jul 6, 2006 | 10:36 PM
spills's Avatar
Car: 89 RS
click on the "pics here" link.
Or are you wantin more pics of the air cleaner?
Old Jul 7, 2006 | 09:25 AM
spills's Avatar
Car: 89 RS
If need be I can pay for some of the shipping, Im needin some cash flow around the house.
Old Jul 7, 2006 | 04:32 PM
REDRIGHT9's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: AUTO
I am interested in the Cat. converter, where you going to use it on your car?? I cant get the summit site to pull up on my computer for some reason, should work on my 91 tbi 305 shouldnt it? (when I get 3 in. exhaust done....)
Old Jul 8, 2006 | 12:52 AM
spills's Avatar
Car: 89 RS
Its a universal cat, so it should work. Its a 3-way cat which I am told is the most efficient. The only thing is that it doesnt have a hole for the smog pump tube because it doesnt need it. So you may be able to use it and just bypass the smog pump, but dont quote me on that.
And yes, I was going to use it on my car. Original plan was to make it street legal, but that never happened. Just put on a bullet and dumped it b4 the axle.
Old Jul 8, 2006 | 06:42 AM
Cherry84's Avatar
Car: 84 Corvette Turbo
Engine: 5.7
Transmission: modified 700r4
600 DP
Very interested in carb.... How much shipped to 27804 ... I have pay pal..
Old Jul 8, 2006 | 02:59 PM
will8's Avatar
Car: 83' z28
Axle/Gears: have no clue
got any pics of the dynomax muffler?
Old Jul 8, 2006 | 03:52 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Very interested in Posi. How much shipped to 70737?
Old Jul 9, 2006 | 11:03 PM
flyin89's Avatar
Also interested in the carb............have pay-pal PM me.
Old Jul 10, 2006 | 10:48 AM
duece's Avatar
Car: 1990 Iroc Z convertible
please get the casting # and date codes off of heads.also see what shipping is to 76013
Old Jul 13, 2006 | 12:05 PM
spills's Avatar
Car: 89 RS
bump
Old Jul 14, 2006 | 04:47 PM
JEFFK734's Avatar
Car: 1988 camaro 1985 camaro
Engine: 350 LT1/355 carb'd
Transmission: t-5/th350
Axle/Gears: 84 z28 posi/3.08 open diff
hey will that posi unit bolt into my stock 88 10 bolt rearend? will i have to buy different axles? does it come with gears?
Old Jul 14, 2006 | 05:47 PM
spills's Avatar
Car: 89 RS
It comes with the ring gear, but no pinion so youd have to get some gears. It will bolt into the casing, but you would need 28 spline axles (unless your car is already equipped, but i think 88 was still 26 spline)
Old Jul 15, 2006 | 09:11 AM
surfertom's Avatar
Car: 86 Z-28
Transmission: 700-r4
cat convertor
sent you p.m. tom
Old Jul 15, 2006 | 06:52 PM
Cable slacker's Avatar
are the heads still available, if so casting #s please thanks
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
