10 bolt posi unit
Car: 1989 Camaro RS
Axle/Gears: 3.23 posi
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
sorry if i sound ignorant but would this work for my 10bolt with stock 2.73 gears? i will be upgrading to 3:73 or 4:11 but i dont know much about rearends and the carriers and what not
Car: 1989 Camaro RS
Posi?
When I purchased the unit the guy told me it was a 3 serires carrier so it will not work with gears lower than 3.0. You need thicker gears. You need a serires 2 carrier, but if your interested I have a spacer I can throw into the deal so your gears can fit on the unit. Someone correct me if I'm wrong please.
if that is true than i would posibly be interested in it but if it needs diferent gears i was planing on upgrading my ratio so if i did that i could just order the gears of the size carrier i would need?
Car: 1989 Camaro RS
Yes that is right. If you order new ones then just buy the ones for the 3 serires carrier. If you want to use the old 2 series carrier gears then I just include the spacer needed.
if you dont sell it in the next week or so i will more than likely try and get it but im just gona check on some things money wise and geting it put in. since i do not wanna tackly that job i already have to learn to rebuild my first tranny
Car: 1989 Camaro RS
Still for sale. As stated before I will include a spacer if anyone needs it to use 2 series gears on it.
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
For the fellow questioning about whether it will fit or not, they will NEED 28 spline axles, only the 89-92 Maros and Birds came with 28 spline axles, all the other years came with 26 spline, so it will not work with those......just a note not trying to ruin a sale here
Originally Posted by chevy_camaro_ss
Thanks for info but it was stated in the beginning of the thread it is for "28 spline axles".
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
