Manual steering box, radiator, steering column
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
I've got a manual S10 steering box that needs rebuilt (pitman shaft has some side-to-side play), stock radiator in nice shape, and steering column from an 89 RS, complete with VATS module and some sort of aftermarket steering wheel. No reasonable offer refused. Pickup in Seward, NE would be nice, but I can ship the steering box, but I don't know about the other two things.
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
$40 to anyone who wants to come pick this stuff up. I've also got a Flowmaster cat back I'll throw in for free.
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
how much for the steering box shipped to jacksonville nc 28540, really interested, thanks
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
$50 shipped? Please make sure you realize, it needs some sort of rebuilding as the shaft has some side to side play. Let me know if this works for you.
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
The axle pipe is cut directly above where it goes over the axle. The rear section is intact. This cam off of an LS1 car. It is a 2.5" kit, but the muffler will accept 3" pipe. It was on the car for about a month and looks like brand new. I can cut the tailpipes off and ship everything if you want it that badly. I will say though, that where the i-pipe is cut, it will be a real PITA to weld it back together. If you want just the muffler, I can hook you up with that for sure.
1992 Trans Am
May 10, 2023 07:19 PM
backtothe80s
Sep 5, 2015 12:39 AM
