Convert your 305 to Speed Density from MAF!
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I did this when my MAF broke and it was cheaper to convert than get a new MAF and cleaned up the wiring in my engine bay (2 less relays to worry about and less restriction for air flow). I am selling the PROM needed to convert a 305 to speed density. It was for my 86 Trans Am, stock fuel tables, VATS disabled, "bit flipped" for the VSS to work with the older cars as well. Asking $50.
All you need for the conversion is a MAP sensor and 730 ECM.
Car: 86 T/A
Engine: HSR 355
Car: 86 T/A
Engine: HSR 355
MAP sensor, rubber hose, and pigtail for the sensor can be included for $20. You'd just need an ECM.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I didn't think I could make it much clearer.
I think he's confused because you forgot to mention he has to repin the harness to work with a '730.
Pretty good deal.. SD memcals are getting expencive now.
-- Joe
Car: 86 T/A
Engine: HSR 355
Oh ok. Well for anyone else confused/intriqued here's the website I used with step by step directions of what's needed for the swap and how to do it. Can be done in an hour if you plan it out and are good at wiring.
My 85 Z28 and Changing a '165 ECM to a '730
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: 86 T/A
Engine: HSR 355
I have a spare small cap distributor, my stock coil, and wiring if you're looking to swap. The car's not on the road yet so I didn't have a chance to really test it out. It's an easy swap too, I did it becuase the stealth ram and a large cap was a big no-no.
Car: 92 longbox s10
Engine: 305tpi
Axle/Gears: 3.42 posi
hate to sound ignorant but i am rather new to this tpi stuff. my maf or mas system appear to be buggered and i wanted to switch to sd anyhow. will thie setup work on an 85? i know it works on an 86 but the maf burnoff relay is quite a bit different. let me know as im very interested
Car: 92 longbox s10
Engine: 305tpi
hey man, just figured i'd let everyone know the chip works great, one question though. you said it was "bit flipped" to change the vss from 4000ppm to the older style buffered 2000ppm correct? i need to order a speed sensor and im not sure which one i need
1992 Trans Am
May 10, 2023 07:19 PM
