Some 3rd genner get this stuff before EBAY!!!
Old Aug 24, 2006 | 08:58 PM
cgb's Avatar
cgb
A hodge podge of 3rd gen stuff. Cleaned out my last little stash in the shop, as I haven't had the time to mess with any project cars in the last year or so.
1. MSD or ignition box custom made mount. It was used in an IROC I had. My buddy made it out of steel. Mounts to factory holes on the driver's side of 3rd gen Camaro's. Could be adapted to 3rd gen TA's / Firebirds too. Would look VERY clean painted / cleaned up. $25 shipped.
2. GM 1982-1991 Chevy F-Body Parts Catalog with Illustrations. Original and in good shape. Part Catalog / listing is one hard binder, illustrations are in the other. $45 Shipped gets it.
3. GM Performance Parts Ignition box harness. GM PT#10037377. GM list price is $100...gmpartsdirect is $73. This is a prewired harness to connect an ignition box ( designed for GM but should work just fine with MSD ) to the distributor and tach...extra long harness allows connection to a system mounted in the driver's compartment. $40 shipped gets it.
4. Misc 3rd gen parts. Relay panel from a TPI Car ( fan MAF etc ). Some of the harness is included. Stock TPI ( coil in cap ) ignition coil. Works fine. Bought to troubleshoot a part that was bad. Stock TPI ignition module from 85 IROC. Oil pressure sensor w/ gauge from a TPI car. TPI upper intake gasket set. Never opened, includes extra throttle body gaskets. Also included is an IAC solenoid from a TPI car, worked when pulled.
The gasket kit along is $16 at Summit. $15 SHIPPED gets everything together.
I also have a 1992 T-5 from a '92 Z28 TPI Ragtop car. Was hard to shift into 3rd when pulled.... This is my last core. Rebuilding them yourself isn't hard at all. Just attention to detail. Parts aren't that bad either. Most tranny shops are charging upwards of $250 for cores when you by a rebuilt tranny.
I just want it gone. $75 if picked up in Central VA near Richmond. I'll ship it via Fedex ground for $125 + shipping ( probably $30-50 depending ).
You can email me at lsmonte87@yahoo.com
I take paypal and US Postal money orders.
Old Aug 25, 2006 | 04:11 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
I wonder if those gaskets will work with SLP runners..
Old Aug 25, 2006 | 06:01 AM
onesweet92z's Avatar
Car: 92 camaro z28
Engine: 355 tpi
Transmission: t-5
Axle/Gears: 373
what do you want for the speed sensor in the t-5 it electric right
Old Aug 25, 2006 | 07:13 AM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
interested in the books. checkyour PMs
Speed
Old Aug 25, 2006 | 09:07 AM
cgb's Avatar
cgb
The T-5 doesn't have one, used it in my swap a long time ago.
Old Aug 25, 2006 | 11:48 AM
olong_us's Avatar
Car: 1986 IROC Weekend, Jetta VR6 Daily
Engine: 350 .030 over 5.7 TPI
Transmission: 700-R4 Rebuilt
ill take the gaskets and relays and stuff in the lot for 15.00 thanks alex
Old Aug 25, 2006 | 03:41 PM
cgb's Avatar
cgb
Okay the relays etc are yours. Email me at lsmonte87@yahoo.com
Old Aug 27, 2006 | 11:09 AM
olong_us's Avatar
payment sent thanks alex
Old Aug 29, 2006 | 01:00 AM
97ramsst's Avatar
Car: 2008 F350 SuperDuty & few F-Bodies
Engine: Twin Turbo 6.4L Power Stroke
Transmission: Yeah, it has one.
Axle/Gears: Yeah, some of those too.
Explain again to me where the MSD mount...mounts. I am interested but I dont understand where it mounts.
Old Aug 29, 2006 | 10:49 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Re: the MSD mount...
Hi, I had sent you a private message that I want to purchase the MSD box mount and havn't heard back from you. I've got the cash sitting here. Want it????
Thanks, Nitro
Drone358
Dec 10, 2015 08:16 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
e3pres
Sep 9, 2015 01:51 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Ian Irvine
Sep 4, 2015 08:08 AM
